S6 Edge Stuck on Samsung Screen
Baher Abusada
4
Hello
i have the s6 edge sm-925f, today i was using snapchat and suddenly the phone turned off
when i turned it back on it was stuck on samsung screen
i didnt update it or root it or anything
and i also cant access the recovery menu when pressing home power and volume up
i tried to install new software downloaded from sammobile using odin, but still the same problem
what should i do? thx
Deanig_12
372
Hello
hey matey have you tried samsung kies? :) i can help if you like? :)
Elfyn1
Active member
Jun 24, 2012
25
I had a similar problem with my Galaxy S5. I could not get past the Samsung screen. I tried everything, Kies, etc., nothing worked. If your device is newer I would suggest going through some sort of warranty replacement. If it is older you may need to send it directly to Samsung for service. My phone was out of warranty so I chose to send it to Samsung for repair. It took about 4 days total time there and back and cost me $70 US. Note I am in the US and bought my phone here (Sprint).
Elfyn
Deanig_12
372
Elfyn
so you tried kies with the emegancy recovery software?
Elfyn1
Active member
Jun 24, 2012
25
well thats bull! yes it does workit need to work for you to put the software back on the phone so the chatting crap
I'm sorry if I gave wrong information, all I know is I could not get Kies to work so I could put the firmware back on my phone. When I finally called Samsung, they asked if I had tried Kies and I told them yes. Then when I told her it was a Sprint phone, she told me Kies would not work with my phone because it was from Sprint.
I never meant to imply that Kies would not work for the OP, just that it did not work for me.
offline050
