S6 Edge Tempered Glass
KingKhal
11
Bought a new tempered glass, front and back, but both not fit well. Front, on top and bottom doesn't stick nicely as the moddle part..... back, the size a bit smaller, it doesn't cover the whole back panel. So, i removed it. Any suggestions of brand that fit well?
Go onto eBay and type this item number in (231805589312), this sellers tempered glass screen protectors fit inch perfect and I use them on my S6 edge, hope that helps.
malik654
