S6 wakelock is at 99% and high battery drain
liverpool1208
Hi , need some help figureing out what is the cause of the high drain. Please also see attached pictures. I noticed that on full charge.. the phone does not last even 6-7 hours. So i installed wakelock detector and it shows that the phone is awake 99% of the time.
just an hour ago my battery was at 50% now now it went flat and switched off. this is weird
Problem is that i am not able to find out what is the app that is causing it. Recently all i did was to install magisk on my phone, could this be the reason?
So far this are the sets i have done:
set phone to power saving
close location
restrict data for google play, google services
optimize apps to save power all time
bring phone brightness all the way down and remove auto brightness
no sync
So any help would be much appreciated. this started happening a week ago.
Magisk would be my guess, try uninstalling that and see if anything changes. If not, you can always reinstall hey...
sellhousefastmke
