S7 edge battery vs note 7
Sam1482
84
Is any one getting better battery or the same as note 7 cause my s7 edge isn't as good as my note 7 and it's set up the same
I didn't notice any big difference on the S7 Edge when I had it, but then again, the Note 7 does have a much larger battery, so expecting the same life wouldn't be fair. Unless you're getting an hours-long difference, then yeah, something might be off.
The S7 Edge has a bigger battery.
S7 - 3000mah
Note 7 - 3500mah
S7 Edge - 3600mah
The phone has been off charge for 5hr 10 mins with 2hrs screen on time and it's at 65% note 7 would be at 70-75
I went to sleep and my battery was at 60, and I woke up at 37. So I do notice that my battery is not that good as the note 7...I used to get 5 hours screen on time with the note.
I'm in the UK I was getting 6hr screen on time with me note it has only been charged twice though so maybe a few more charges and it will be as good as the notes
I was getting better battery life on my S7 edge over the N7. Im back on another S7 edge and its still gets better Battery life.
This will be my first day with my S7 edge so I'll hold off on any battery comparisons for a few days. My original Note 7 battery wasn't as good as my replacement Note 7 battery was, that's for sure.
My S7 Edge battery life is much better than even my replacement Note 7, which was pretty good. The Edge seems to sip battery. I installed a ton of apps yesterday after going off charger around 6:30AM, and still have over 50% at 10PM. I haven't started playing games or anything yet.
Well I now have the s7 edge. Boy do I miss my note 7 but I seem to be getting better battery life from the edge
Gillian Kirton
