S7 edge continuous charging?
Air Planet
97
Using wall charger or wireless charging If we continuosly charge s7 edge after 100%
1)are both Charger will automatically turned off after full s7 edge charged ?
2)and if both charger turned off after full s7 edge charged and then 1 percent or few percent battery consumed then thesr both chargers automatically will start charging again of s7 edge ?
The phone is smart enough to not overcharge it's batteries, if that answers your first question.
I also believe that it will also continue to charge the phone at intervals over time, but I have no experience of that.
it means in 2nd question answer s7 edge battery continuously using battery life cycle which is bad?
Lithium batteries aren't that sensitive to that like the old NiCad ones were.
It's still recommended that you let it run down very low now and then just to reset the circuitry that controls the cycles and measurements..
sfvsfvbf
