S7 Edge to S9+
waqqas31
717
139
43
The only thing that suffers is the sharpness of indoor and low-light pictures. The noise reduction in the S9+ crushes the detail, but if you only care about the way a picture looks when fully zoomed out, you will be ok.
anon(5719825)
Retired Moderator
Feb 21, 2013
3,797
How's the battery life?
I have the US unlocked S9+ and the battery life on my phone beats any other phone I have ever had, even my Note 9 with it's bigger battery.
I also had a US unlocked S8+ last year and it too had battery life as good as my S9+. I think the unlocked models have better battery life then the carrier versions. I started finding this out when I had a T-Mobile S7 Edge and a US unlocked S7 Edge. The unlocked version always had better battery life.
dpham00
Moderator Team VP
Moderator
Apr 23, 2011
30,108
200
63
It is not a huge difference but there are some improvements. The curve on the s9+ is way better than in the s7 edge, imo. There are other improvements like more accurate fps(albeit on the back) , louder speakers, faster cpu, more ram, better camera overall.
Hermes Hidayat
2,630
5
38
Hi what's people's experiences with the upgrade from s7 edge to s9 plus is it worth it?
okay i might not have moved from S7 Edge to S9 Plus but moving from Note 8 to S9 Plus is already a big jump for me.
and comparing the latest S series to a 2 year old S series isnt really comparable...but in my opinion if you can wait for S10 then you should.because S10 would have newer processors and bigger RAM.
Alex432
