- Feb 17, 2011
- 331
- 1
- 0
I have enabled developer options and USB debugging, but there does not seem to be an option to put the phone into Mass Storage Mode to enable the phone internal and SD storage to show up as drives on a PC. It only seems to want be in anything other than Media Transfer Protocol mode. There are some USB "NETWORK" settings under the developer menu that would seem to allow you to select something other than MTP (except mass storage is not a selection), but even changing those settings does not take it out of MTP mode. Any suggestions? [Removing the microSD and using a card reader is possible, but the process is a PITA and that does not allow you gain access to on board memory]. Media files need to be in very specific directory locations on internal and external memory for the files to be visible to the VR headset, that is also why I am wanting to gain traditional file write access to memory. Thanks.
