A Adrian Wink New member Jul 1, 2013 1 0 0 Mar 31, 2016 #1 I cannot fit my samsung s7 edge in the vr am I missing anything my s6 edge fits perfectly before I lost it
bigslam123 Well-known member May 3, 2010 707 28 28 Mar 31, 2016 #2 Make sure you are not using a case. My S7 Edge fits perfectly. Posted via the Android Central App
KillerQ Well-known member Feb 23, 2011 1,092 24 38 Apr 1, 2016 #3 Adrian Wink said: I cannot fit my samsung s7 edge in the vr am I missing anything my s6 edge fits perfectly before I lost it Click to expand... Have you switched the connector for the USB from position B to position A? Posted via my Nokia 8210 from the inside of a Kitten.
J JJ Jones Well-known member Dec 14, 2012 554 0 0 Apr 1, 2016 #4 The 321 version is also known as the Innovator edition and was designed for the S6. https://forums.androidcentral.com/e...7%2F997341113%2FSM-R321NZWAXAR&token=1FHxqwDr From my AT&T Platinum Gold Note 5
