S7 Edge with PEN
Momof9Blessings
117
Well I finally had time to play with my pen... I bought an Intuos Creative Stylus 2 from Best Buy. It is designed for the iPad but works great using the bluetooth on my s7E. I also downloaded Google's Handwriting Input App and it works great! It is an alternative keyboard.
I need to see if the pen has pressure sensitivity. But I like it much better than using a rubber tip pen... :)
I am glad you posted this. When you first posted I looked at the pen and it said it was for iPads. I am now going to look for one. Just sad there is no where in the phone to store it.
By any chance could you test this out on some of the art programs like Artflow, Artrage, Sketchbook?
That's the big failure, skatergirl - there are a lot of good styli, but you still need a pocket or something to store it.
I don't care if there is a slot or not for the pen. I usually use the old Note 2 pen accessory. Which is big like a normal size pen
I kept the S-Pen from my Note 7 when I returned the phone. Wonder if I can get it to stick to the top (metal portion) of the S7E with a magnetic strip.
I have used the pen in art rage etc. It works fine, but no pressure sensitivities as far as I can tell. I am curious about the jot pro and stilo. They might work as well
Quiant
