will the battery the 3d battery be the same size as the OG evo? i just bought a seidon extended battery i just wanna know if this will fit in the 3d ?
would you b able to use the same extended battery or will it mess up the phone?
I believe the battery capacity of the EVO3D will be 1750mah....the EVO 4g is 1500mah.
Plus i think the EVO3D will offer better battery life overall due to the dual core
Actually, if the same reasoning applies from computers, more cores=more power draw
If it is the same dimensions, then it should be fine to use.
