Same size big capacity battery
Pretty sure it's nearly impossible to get a bigger capacity battery into the same size port. That's why all of the extended batteries come with new, bigger backdoors. Still, can't wait to hear if this works for you.
I got one from eBay (4,000 mAh I think) and it works wonderfully, just misses out on NFC (which I don't use too often)
I'm like you.... I don't buy it. I know battery technology is advancing but cmon. Increased capacity and cheaper than standard oem?
Posted via me
You are right. Capacity is not as advertised and is still 3000mah. I returned it.
Chauncey the Gardener
