Samsung angled fast wireless charger
russel5150
1,274
6
I ordered this in a bundle pack from verizon because i really wanted an angled one to replace the flat one i have.
It works good with the s7, even in an otterbox defender, however my note5 will not charge with an otterbox defender on it.
Its not the case itself on the back of the phone causing the problem i dont think, what appears to be happening is with the added case on the sides of the phone it wont allow the wireless charger to line up like it needs too. Even the candyshell grip case wont let it line up, however with no case it works fine.
Like i said the charger works fine with the s7 in an otterbox, and a motorola droid turbo in a speck case.
This is kind of discussed in the s7 forum, but i fig it would be good to post here too.
**edit: I messed with more when i got home from work, all i can figure is it doesnt like the note5 having any case on it. So i will keep using the flat fast charger, it works fine with a case on the phone.
Sent with my white Note5 with nonremovable back and no SDcard!
I had the same problem with my Nokia Qi stands. And that's because the Qi coil on the S7 is really picky (it's probably a lot smaller than normal) when it comes to the placement.
What I'm almost 100% sure happens on the Note 5 when you add a case is that the extra hight the phone gains is enough to misalign the phone's coil with the charger's.
Interesting. I have noticed it seems to be much more forgiving. My Note 3, gs5, and g3 all had to be exact but my s7 has almost 1/2“ wiggle room, if more than 1/2“ is off the mat then it won't charge
The most important question...will the charger fit into the prius cupholder ?
Would be easy to hide the power cable in the console and the phone gets placed into the cupholder anyway while driving most of the time
Kenny
Does charger turn off or provide trickel charge keeping battery topped off?
Thanks
I have been using this charger nightly for the past six weeks. My S7 is in a Spiegen thin crystal case. Every morning the phone comes off the charger at full 100% charge. Perfect charging, and i like being able to view the AOD in the upright position.
Mine has been good up to yesterday, I had been charging it with the S7 horizontal fine but yesterday it would only charge with it vertical - horizontal only yields blinking blue LED. Not a good sign.
tota
