Samsung Edge Panel > Widget Edge > One Drive Widget/Shortcut
varxtis
8
So, Edge Panel got installed on my phone the other day and I got really excited. With the "Widget Edge", you can add widgets to it as you can on a home screen. However Im running into a problem with OneDrive. You can place shortcuts to specific files and folders of your OneDrive directly onto your home page via the Onedrive Widget. But when I try to do the same thing onto the "Widget Edge", it simply adds a generic "shortcut" to onedrive without allowing me to specify a desired file or folder. Is there a trick I'm missing? this is very frustrating.
The edge panels are pretty simple in what they do, they're more a shortcut themselves. If you're not seeing the functionality you need, you might contact the developer of that panel.
Sky234
