• Welcome to the all-new Android Central Forums! - We're still moving some things around, so you may see a few quirks here and there, but we're working on getting things fully completed as soon as possible. For now, take a look around, and if you run into any major issues please let us know in this thread!
Samsung Galaxy note 3 killing batteries
A
AC Question
Hi
A friend of mine thought his phone was having issues as his battery was draining fast and eventually wouldn't hold charge. He purchased an Anker battery but the same was happening.
Long story short we swapped batteries so I could charge his phone battery for a while and he could use what was in mine to use his phone and now after he has used my battery mine is showing the same signs. It's been on charge for a hour or so and dropped 1% with little to no use.
It seems his phone is somehow permanently killing batteries? any ideas?
Thanks
belodion
Co-Ambassador Team Lead
Moderator
Jun 10, 2014
39,082
13
38
Welcome to Android Central.
What do the battery usage stats reveal after these discharges? It ought to be possible to glean a lot from them, especially taking other things into consideration, such as location settings, sync settings, signal quality.
g1ose
5
Hi
Not much of use as the usage was done in another phone. I have been charging the phone since posting this and its up to 50% from 29%.
When I originally gave him the battery it had 75% and went down in 1 hour nearly 50% to 29%
Normally charge over 4 or so hours should provide more than 21%? The phone isnt being used other than an occasional time check.
LeoRex
Retired Moderator
Nov 21, 2012
6,224
If there was a problem with the power supply in your friend's phone, it is possible that it could have caused permanent damage to the batteries themselves.
And a damaged or faulty battery is BAD NEWS.... as in "spitzen-sparken boom" bad news. I suggest that your friend get his phone serviced and you order yourself a new battery. You don't want to take chances with those things, they may be small, but they hold a LOT of electrical power and are not to be trifled with.
Ask The Community
COKEDUDE
