Samsung Galaxy S6 Fast charging car charger?
smalba
501
5
18
So the charger that we get with the s6 is fast charging but will they have a car charger that has this ability for the s6? Or maybe someone else already sells one? Also can we use other fast chargers like the one on the note 4 or the moto x?
Re: Fast charging car charger?
I'd like to see it incorporated into the cars dash. Just lay in a slot or on a spot just below that center console. It is a shame that wireless charging is rapid . That would be sweet in a car. Isn't pretty much anything compatible with the GS6 going to make use of the rapid charging capability?
The new Toyota Camry's have an option for a built in Qi charger. I hope other car makers follow this idea.
I've been using the PureGear one and it's been great. Fast charging (that's the point isn't it?) Small but still can get a good grip to remove it when changing vehicles. Dim white light to show power, even though I almost never see it because it's located inside the center console of my truck.
PureGear Qualcomm Quick Charge 2.0 Extreme USB 12W Car Charger, Black, Single Port
This too...
I want a Dual USB car & Wall ac adapter
to fast charge my Note Edge & S6 Edge ;)
Please post links if you know where i can get it
Just make sure it is compatible with the GS6. The last thing we need is very hot brick or a melted one or even one that catches fire.
I ordered the Incipio plug online, probably paid more than I needed to (at the time, I didn't see any deals), $34.99, but worth it. I bought a cable for $5 from Walmart and when I plug it in, I get the 'Fast charger connected' message and that it does!
Posted via the awesomest phone EVER...the Note 4.
I am hoping that my Samsung OEM car charger will work on the GS6.
dumpsterrentals67
