Samsung Galaxy S7 Edge - MicroSD cards, are yours working fine?
JohnMidnight
8
I bought a PNY 128GB for the new phone off of Amazon (I would link the specific one, but 10 posts are needed for that)
Worked great, till I get away from home and leave behind a microsd-SD card adapter, because the SOB hates the SG7E. IT works fine in my SG5, but no longer in the 7, ideas?
My 5's 64 GB is now in the device and working fine. Not. Happy.
Re: MicroSD cards, are yours working fine?
I would try to format the csrd the and try again
I've had so many issues with non-Samsung SD cards on my other Samsung devices I just avoid them altogether now. My 128GB Samsung Pro+ is running like a champ right now thankfully.
I figured out I could do it on the G5, I formated the 128, then unmounted and removed card. Unmounted the 64 from the 7, installed the 128 and all good.
KimJongOMG: My first PNY card >.> usually, strictly, buy Sandisk cards >.>
Update: Neither Sandisk card or PNY card are readable on the Edge 7 when files are added via USB cable.
Tried my Class 10 Sandisk, vs the Class 4. Class 10 works fine so far, not a single issue. the PNY is a "Class 10" but not a 11, 12 >.>
I love PNY cards but I've never used one in a Samsung. I've ALWAYS had issues with a SanDisk card in my Sammies which turned me off non-Samsung cards altogether.
Where are you buying these cards? There are so many counterfeits out there these days it's disturbing.
Got a Samsung Pro+ and it works like a charm
Bought and installed a 64gb SanDisk and it works great! Absolutely no issues so far.
whiteraice
