• Welcome to the all-new Android Central Forums! - We're still moving some things around, so you may see a few quirks here and there, but we're working on getting things fully completed as soon as possible. For now, take a look around, and if you run into any major issues please let us know in this thread!
Samsung galaxy tablet 4 battery drainage issues
ThunderDark
My Samsung Galaxy tablet 4 has major drainage issues like i can use the tablet normally but once it hits like 68% ish battery mark it drains so fast and it has been like this for awhile now. Awhile back my battery had a drainage issue and i sent it to samsung for a free repair (under warranty) and it worked for awhile and all of the sudden it went from if my battery was on 20% battery it would drain super quickly like how it is now instead its worse! It does that around the 68% ish percent mark and i have tried many things my last options are buying a new charger or replacing the battery. I am wondering if there is a way to fix this battery drain issue without going to those lengths.
Tech-Newb
630
Looks like the battery is bad. Buy and replace the battery.
Posted with ❤Love❤
Rukbat
Retired Moderator
Feb 12, 2012
44,533
18
You're probably killing the battery by constantly draining it to 20% - lithium batteries don't hold up well if regularly drained past 40%. A constant 20% bottom level should give you about 6 months. (Never dropping it below 50% should give you 10 years or more.)
Ask The Community
knkk
