Samsung J5 (2017) problem after lcd replacement
vhmp95
Hi, i have an problem whith my samsung j5 2017 (sm-j530f).
when i change my phone lcd and i turn on the first time my phone work fine. But when i take it out again to glue in place it wont turn on. I put it to charge because it has no change and the charging icon appers but right away, it shows an black strip and it wont turn on, just frezze in that spot. if a disconect the charge and plug it again it does this all over again.
I try disconect the battery over night. try to boot on recovery mode and nothing. Leave to charge for some time.
There is an link on and youtube video i made so you guys can see the problem.
Unfortunately there are a LOT of things that could have gone wrong when attempting self repairs. You might have damaged the connector or circuits with the hot glue gun. If you can you should try a different screen without gluing it in just to see if you damaged the phone or the screen assembly itself.
As can you see i didn't use hot glue. i use two side tape and i didn't fix the screen yet. If i leave the phone changing, it enters an loop betewn the problem show in the video and then shut down.
Could be some SO probem maybe it corrupt somewhow.
Hi. Did you end up resolving this issue. I am in a similar situation
Welcome to Android Central! It's unlikely that member is still following this thread, since it's been almost 3 years (and those were the only 2 posts the member ever made). You may just want to take the phone to a repair shop, unless you have a lot of experience repairing phones yourself.
