Samsung Mega Wont turn on anymore? please help
Irvin Lopez
6
Hi so i have a samsung mega 6.3 from at&t and today i decide to restart the phone but the phone never turned on anymore i tried taking the battery off for a couple a seconds and i tried charging it but nothing shows up in the screen. what is it?
Welcome to Android Central! When you say that you decided to restart the phone, do you mean a simple power off/power on, or a factory reset?\
Try pressing and holding the power button for about 15-20 seconds.
The battery might have failed. Try a new one, if possible. You can confirm a battery problem by taking it out, placing it flat on a table, and trying to spin it. If it spins freely, it's bulging in the middle, which is a bad sign. But even if it doesn't spin, it could be a problem, so the absence doesn't rule it out.
wont power up
my phone wont power up
wont power up at all whats the problem?
Hi , I have a samsung mega 6.5 from sprint and my screen show for give update and i did it and now my phone dont turn on , just turn on when i plug to the charger but in one min turn off again
suranjanpaulmanik
