Samsung Note 3 Weather can not locate my location
nnguyen0128
Hello, I am new with the Samsung Note 3.. this is my first samsung phone after many many iphone
On my Note 3 the weather app can not locate my location, Every time I tried to add my current location, but it wont let me allow to add .
on the screen is only some the Benji, China temperature. It wont let me ad my US location.
Is there anyway i can add my location on or get a new app for weather. Thank you
Tons of weather apps to use. The Note 3 uses a version of AccuWeather for it's weather. You can try downloading the standalone version of Accuweather, Weather Underground, or WeatherBug, as they are three of the more popular weather apps. 4.3 software on the Note 3 sometimes causes a bug with the stock weather widget. Kit Kat 4.4 fixed it. Not sure which version you are running.
Benji, China temperature only? Are you sure it's a real Note 3, made for use in the US? Install Genuine Galaxy - Phone Info to make sure. If it gets the location wrong, that's normal. (My Note 3 weather app shows my zip code to be a different town nearby, so I have to put the city name in by hand. Weather apps aren't great at location. But halfway around the world? That's not just a bug.)
