Samsung Note 9 gap issue
  • Start date Start date
A
Android Central Question
Hi there,
I have a Samsung Galaxy Note 9 and the phone appears to have a gap between the screen and frame of the phone with a piece of dust or something caught inside,
Please can someone get back to me soon!
I don't have that issue, did you drop it ? if not have you talked to the place you purchased it?.
My note9 should be shattered to pieces as many times I have dropped it on the screen, back and sides on concrete floor at work lmao. Not one scratch. Thank goodness. Most of the falls I had a thin case on it.
OMG ..my luck one bounce done , I also have thin case.lol
I've never seen it either - can you gently remove it with a toothpick or something non-metallic that would not damage the screen? Just gently scrape into the crevice and see if you can get the dust piece to come out.
*As with all Mission Impossible Missions Mr Phelps, I disavow all knowledge of these instructions! This Message will self destruct in two days!
David1972
