Samsung S7 Edge Battery Health
Arslan0307
3
Hello Everyone!
I have Samsung S7 Edge. I want to know the information regarding my phone battery health.
1. My phone battery health is 78%. I need to know that is this percentage is good for healthy battery? And also what is the percentage for healthy battery? and how this percentage increases or decreases? if i say my battery health is 60% then it is still healthy or not? how much time it will last long?
2. My phone discharging cycles are 774. what does this cycles mean?
these should be higher or lower in number? what is the range of these cycles for healthy battery? i really don't know what these cycles actually means?
Thank You!
Hello Everyone!
Thank You!
You're health at about 80% is okay, basically 4/5ths of new.
The cycles are the amount of charges and discharges above a programmed threshold, which is calculated by the amount of time you have been plugging it in to charge. 1000 cycles is a target number for a liion battery, so you're still good to go.
thank you sir,
What if my battery health percentage will be 60% but discharge cycles are 401. then what you will say about this battery? Actually this is the stats of another samsung s7 edge.
is this battery is good enough? how much time it last long? approx after how many time i need to replace this battery? and battery health 60% does imply anything? or it is still good or bad health?
AdamMeyer
