Samsung wireless charger duo is garbage, what wireless charer or 3 in 1 you recommend?
delta7
826
6
18
Apple has some pretty good ones for the watch, phone and airpods but samsung doesn't have much. The wireless charger duo is trash and I'm throwing it away, take 2 hours to charge lol
What you guys use? You recommend that 15watt wireless charger?
I have two of those samsung wireless chargers and no problems at all with either of them. I use them for my s21 ultra. It charges pretty fast for my use, but never over 2 hours, maybe a little over ah hour with the phone and the watch 4. Could be you have something running in the background on the phone that is draining power while charging.
Are you sure wireless fast charging is turned on in settings?
The Duo pad isn't the best charger, but it meets my needs... Or at least it used to. they do have a new one now that charges at full 15w, but it doesn't fast charge the new watches lol.
I've looked at some third party ones and they all look like trash... none of the trusted brands seem to make them, it's all no- name stuff.
If I needed my phone to charge quicker than 2 hours I would use a corded charger, not wireless. My Intoval Wireless Charger can charge my S21 Ultra, a watch and Buds. I just set my phone on the charger when I go to bed and it is fully charged by the next morning. I usually get 2-3 days out of a charge anyway, so there's never any hurry to charge it fast.
I got it off offerup for 30 bucks and I think the charger isn't the proper one hence the slow charging but I cannot find the proper charger online so I'm throwing it away.
I got the charger but it's losing charge and only says fast charger. Doesn't seem to work with the Fe
Do you have the old or new Samsung wireless charger duo? The old one is only 9 W. You'll need the new one to get 15 W.
r3dpuk3
