Samsung wireless charging hockey puck
dfb8085
215
Anybody trying the wireless charging puck from Samsung. So far this thing sucks. Can hardly get the phone in position to charge. I have to continue to wiggle and move it around slightly over and over to find the sweet spot. Then when I get up in the morning its cut off and the phone is maybe at 90% charge. Does using a thin case hinder the charging connection?
1. A case shouldn't hinder charging. (I charge through an Otterbox Defender, and that's not "thin".)
2., The S6 will charge on a Qi plate, and a 3-1/2" X 6" (about the standard size) Qi plate with a charging light will make it a lot easier.
Hi guys I have an S6 edge with a 3M carbon fiber Sticker and a Goopery case on it and have no problem charging the phone overnight, the only thing to be done is to make sure you place the phone correctly over the charger and shut down the vibrations notification. Hope this helps.
I have used this charger for 6 months or better but really havent had too many problems with it. Once in awhile my phone receives a notification while charging and the charger flashes blue and starts draining slowly. However today i took the phone off the charger after receiving a notification and the charger was flashing blue and the charger continued to flash blue. Any idea as to why this may have happened or what is causing it? I haven't yet just unplugged the charger as I am watching the Seahawks game< i am sure the turning off and on of the charger should reset it but wondering WHY it happened. Anyone? Thanks in advance
