Sand in between glass and outer plastic on Moto G. HELP! What should I do?
  • Start date Start date
A
AC Question
Basicly, I was very stupid and dropped phone in sand, I have cleaned most of phone, but on left side, between phone and glass, theres sand, which can be noticed, I tried various methods suggested, vacuming, using paper to push out, but its only had miner effect. Plz comment if have solved for yourself! Thanks!
Re: Sand in between glass and outer plastic on Moto G. HELP!
The solution is to remove the digitizer and, after very fully cleaning the phone, replace it with a new one. (Next time, if you're going to be near sand, put the phone into a sandwich baggie. A digitizer costs a lot more than the 2 cents the baggie costs.)
