screen and colors going crazy...help?!
sirk0rebreg
64
for about the last 3 weeks my phone seems to be on crack and doing whatever it wants...majority of the time the screen won't turn on or even come on if there is a call, etc...if/when it does come on, the display is upside down, the screen is all colored red, blue, green, yellow or whatever color mood it is in for the day, if I turn it off and on a few times that will clear up the color issue, but the biggest problem is that the screen doesn't want to turn on most of the time at all! i can get it to turn on if i plug it in to charge, but most of the time outside of that i have to get lucky to have the screen come up...
anyone else having a problem like this? anything i can do? do i just need to go get a replacement?
3 weeks? wow you are patient! you might call verizon, but they may tell you it's the software... I would try installing another stable ROM as long as you know you have a battery that is well charged through the process
I've had the best luck with the CM7 ROM - stable!
I second that. Try and ODIN the EH03 leak. It is ultra stable and should clear up your problems.
edc
