Screen Rotation issues
prashramani12
Active member
Apr 26, 2012
25
Hello,
I've noticed recently that I am able to make my screen horizontal, but it won't go back to being vertical, unless I open some app that has a vertical setting, and then I shut off screen rotation so the problem doesn't persist?
FYI, I am running 4.0 ICS (the UK version)
anyone know the issue/ how to fix it? Thanks!
Check the display settings of your device. In the orientation option tick the auto orientation check box.
The issue is that I can go from vertical orientation to horizontal orientation, but I cannot go back, and I don't know why
mystiqarelab
