Screen wont lock and wi-fi wont connect
Aphex_uk
Ok, so i got my S5 3 weeks ago. loving it so far, apart from now.
The screen wont lock when i press the power button. If i hold the button down, I get the option to turn it off, but it wont lock. The screen is always on and heats up the phone. Also the wifi wont connect to anything. it can locate networks, but just keep trying to connect.
Can anyone help with this?
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
166,151
5,598
113
Welcome to Android Central! It's new enough that you may just want to bring it back to the store and ask for a replacement--if you wait longer, you might miss the window to do it through your wireless store.
If you don't want to return it, try booting into Recovery Mode and wiping the cache partition: Reset: Samsung Galaxy S 5 | T-Mobile Support
possible11
