SD card file management problems.
Sujay Kadrekar
Active member
Mar 30, 2013
28
With Android's new privacy policy on KitKat, it is impossible to alter SD card files on the M8 by a third party file manager. Yes I know the trick is to root the device and install SD fix apps. But my phone is still under warranty and I don't want to root it and loose my warranty. I used to own a Samsung GS4 earlier which had inbuilt Samsung file manager, through which I easily altered SD card files. Does HTC have any such file manager hidden somewhere? Is there any other solution without rooting the device?
i realise this isnt a fix, but you know if you plug your phone into a computer via usb, you can manage your files from there?
I only suggest it because generally, I don't need to do much to my sd card files, but when I do, my computer isn't far away, so I haven't found a great need to find a proper solution yet.
agahsha8
