SD storage problem
jwalker007
87
I have a factory unlocked version of an HTC One M8 on AT&T running 4.4.3. I noticed a week ago I was having issues with Pocketcasts freezing. It stored its files on the SD card so I moved them to the phone storage. It seems to be working fine now. This week I have been taking pictures with my HTC M8 and the gallery freezes and the picture will turn blank with a triangle in it. The camera stores pictures on the SD card also. If I touch the picture the phone locks up. Any help would be appreciated.
Sent from my HTC One_M8 using Tapatalk
Do you have a computer (laptop/notebook) that has an SD slot? If so I recommend you insert it into the computer and have it scan the SD card for errors. While you have it in the computer you might want to copy the contents of the SD card on to the computer format the card, and then copy the files back over to the card again. (Make sure to unmount the card in storage settings before taking it out of the phone, and to eject it on the computer before pulling it back out after the scan and possible format).
