cheebahawk1
- May 28, 2010
- 203
- 1
- 0
I bought mine directly from androidcentral and love the case.
But one problem I have with mine is that the bottom of the silicone is very loose, and I will often find it sitting below the outer rim. Also the exoskeleton does not sit flush on the left side, there are significant gaps between the exoskeleton and silicone case (which isnt the case on the right hand side).
Called Androidcentral this morning and I gotta say I was thoroughly impressed with the CS. They didnt give me any problems, and sent me a replacement for Thursday this morning.
I would recommend ordering directly from Androidcentral!
