Seidio Innocase Side Case for Droid
baycruisers
231
I have the Innocase Surface case, which I like very much. Seidio is also offering a side holster that is supposed to work with the Innocase. However, it clearly states that it uses "two strong magnets" to keep the case cover closed. I'm concerned that these magnets would put the Droid in car mode and drain the battery.
Has anyone purchased this case? Any testimonials?
Premium Horizontal Leather Case
I am using a generic leather side case with a magnetic closure. If you put the screen in facing out, you shouldn't have a problem. The magnet sensors are on the back of the Droid, so they are unaffected by the magnets in the front. Just make sure there isn't a magnet in the back like there are for Blackberry cases. If there is, you will then have a problem.
I would look into the clip case that has no magnets or try email them for the answer they have good customer support.
mitiku Berihe
