Select Keyboard notification will not stop.. help
fisherman13
My Galaxy S6 started to give me a beep and vibrate notification a couple days ago. The phone would not show any notifications. I installed an app called notification history and the android system keeps asking for "request keyboard" I have done this and the message comes up and/or vibrates about every 45 seconds. What could be causing this and how do I fix this issue?
Hi, I was a victim of this thing too and have a creative solution - replace the notification sound by a silent one you create:
- Use your smartphone voice recorder to create a one second silent notification - just press the record button and then immediately again.
- An ma4 sound file is created
- Rename the file to whatever name you want
- Share it - email it to yourself
- Go to your email inbox open the email with the fole and save the file - it will be saved in the "downloads" folder
- Go to Seiings -> Sound and Vibration -> Notification sound -> Deafault Notification Sound -> and change the sound to the one you created
Now it can notify as much as it wants - you will not hear it - like a mute person shouting- Hahahahah...
Noob
