Semi-bricked phone, RUU issues, please help!
Jagerlowe
7
So last night I flashed the gingerbread coredroid ROM and it worked fine. I just didn't really like the looks of some things, so I thought I'd change to a different ROM.
I thought about flashing the ICS Insertcoin ROM, so I flashed it, and it kept trying to boot, but turned off and kept repeating. But then I read that I was supposed to update the firmware, so I took out the SIM card and connected it to the computer and copied the 3.24 RUU to the SD card.
I followed the instructions and the RUU set up properly through HBoot the first time. Then i went in to recovery to wipe data. It had to reboot the phone before I did anything else, and it went back into HBOOT and tried to install the RUU again, but this time it failed due to CID being incorrect! I didn't give it a second thought, but then the insertcoin ROM was doing the same thing, going through the boot up images and shutting off right in the middle, and repeating.
I tried another ICS ROM, Android Revolution, and same result. Failed booting. Then I tried restoring my nandroid backup from before coredroid, and it also kept trying to boot and then shut down. Then I tried coredroid again, and it had the same reaction, failed booting! I redownloaded the ICS RUU 4 times and repeated this process 4 different times, even with other GB versions of insertcoin and ARHD, and no dice!
I'm not entirely tech savvy, so maybe there is soemthing I havent covered yet. Now the RUU fails not because of CID, but because of incorrect Model ID. I read about goldcards, but I can't make a new one because the phone won't even boot! Please help me!
In the same boat my friend been trying all day to restore my old backup but it just keeps going to splash screen, the insert coin robot starts to blast off and then it goes black then to the htc screen again. This started earlier today when i attempted to update to 3.24 as well.
Resolved. Downloaded the wrong country firmware which causes the wrong cid error. I mustve downloaded the one from China *facepalm* :)
kolilco1
