SERIOUS Reboot Problem, Apparently Caused by Bluetooth
Rackstraw
Active member
Apr 6, 2009
43
Forgot if this is a known or common problem.
Mine is the Verizon NotePro but with service turned off, so I keep it in Airplane Mode. Paired it with the ZaGG Coverfit Keyboard.
Sometimes when in use, it will restart with no warning. Then it'll barely get past the loading screens and restart again, threatening to stay in this loop until it loses power.
One trick I've found is, if it even gets to the unlock screen, to quickly toggle bluetooth off. That seems to help.
Otherwise I have to find the right time to hold the power button down so it will stop restarting. Even then; no guarantees it won't just get caught in the same loop all over again.
Obviously frustrating to use it when this could happen at any time. Anyone know the fix?
