Setting up my phone, I have a few questions
iamloco724
152
I got it yesterday and im in the process of setting it up to see if I like it and put it through the motions, I havnt put in my sim card yet I figured I would wait until im fully setup or im sure im keep iy.
For now I have a questions and im sure I will have more
Sometimes after i take a picture with the camera I can delete a photo straight from the camera software other times i have to go into the photos app to delete, am i missing something that im doing differently between those two times?
Is there a way to restart the phone instead of just powering off?
Is there a way to remove the Google bar from the homescreen I tried to drag it off to remove and it wont give me that option?
This is it for now as I really just started playing around with it I am sure I will have a few more questions
Yes, click the pic on the right that you just took, then delete
No
You can download other Launcher apps, like Nova Launcher. Can't do this with stock google launcher
The answer to question 2 is yes -
Long Press your power button and you will get a screen that has options to:
Power Off
Reboot
Airplane Mode
The above is true for pure 4.4, 5.0.1 and 5.1.1
Hope this helps in some small way........
Power Off
Reboot
Airplane Mode
Either they removed that from 6.0 or the 6p just doesn't have it.
Highly recommend Nova Launcher. And if you got the $50 Google Play credit, get the paid version. You can do a lot of customization that really makes a difference aesthetically and from a user experience. Highly recommend.
penguin_sam
