- Aug 9, 2016
- 12
- 0
- 0
I m using Sm N910T and I m on the stock marshmallow rom 6.0.1 N910TUVS2EPG2
I m really sick of this update
I have this issue of severe battery drain by two main culprits at Number one it's MEDIA
and number two is ANDROID SYSTEM. I have already cleared cache using recovery and cleared data in settings. Have checked most of my pics and videos. My battery won't last more then 4 hrs. I have disabled most of the bloat apps and quite a bit of Samsung apps. Sync is @ manual
Android system cpu usage after a whole day typically is around 6 hrs
Media cpu usage usually is around 5.30hrs
Searched through the net and found no real fix for the battery drain
P.S - I DID THE FACTORY DATA RESET 1 2 TIMES.
Please help
Please help
