Sholes 2.0.3 question, please help!?
stefanl
79
I absolutely love this Rom. I also use SetPC to overclock to 800mhz....incredible. BUT, just a couple concerns:
1. When i play a couple of new games (Homerun 3D, and Air Control) and lose, it wont just take me to the menu screen, but instead will reboot my phone. This has also happened once while opeining the camera. Is it my app or Sholes?...by the way i highly recommend those to games i mentioned.
2. I constantly have the 'syncing' icon up in the notification bar (the cycling arrows). this is a new development. How to i get it to go away?
3. Typing seems drastically worse. I use Better Keyboard but I've never had a problem with it before. Now, when i'm typing fast it will just not register letters i type. So, when i type 'what' it will just not register the h, and instead get 'was'
4. One more... I have it clocked to 800mhz and its blazing fast. But without purchasing the thermometer app, how do i know how hot is too hot. Sometimes i do feel a little warmth coming off the back, but it may just be in my head from being paranoid.
The help is greatly appreciate! Thats the greatness of these sites
thanks
thebizz
phone addict
Nov 8, 2009
3,568
42
Prob sholes but hadn't had this issue
Turn off sync then turn it back on
Something to do with that keyboard try with the stock one
Don't worry about buying that it only works with taz's kernal
thanks
I hope this helps you
wadeharper
