Should I drain my Droid Turbos battery on first charge?
Seremedy
449
should I drain my droid turbos battery on first charge ?
I just bought the droid turbo today and was wondering if I should completely drain my battery or just till about 20 percent ? And should I use the turbo charger as my daily charger or use a lower output charger ?. Thanks.
Posted from my 64 GB Droid Turbo black nylon
re:
No, there is no reason to drain the battery on first charge. Just use it as you normally would.
