Should I get one need help
Only you can answer that. Do you feel it is enough of an upgrade or worth the price?
Yes indeed...
?worth it? is quite subjective. Is it a solid, feature-rich phone? Absolutely. Is it a great bargain for the price? No question. But whether or not getting it will be worth it to you personally is tough to say. I had the N4 too though, and fwiw the N5 is on a whole other level in numerous ways. So if you can afford it without any real financial inconvenience, I say make it happen!
Nexus 4 to the Nexus 5 will get a better-specced device that will deliver much faster performance, new Android 4.4 KitKat software out-of-the-box, improved camera, upgraded battery and LTE support,
Nexus 5 is a great deal for those looking for a value for money performance Android smartphone.
Pogojeal
