Shut, how to remove the body glove case?
Kronko
651
23
Hi,
I am using the body glove case for the thunderbolt but it is a pain in the neck to remove it (well, if I am ever able to). Does anyone is using it and willing to provide info of how to remove it, an easy way exists? I am almost ready to break the d....n thing. Tia.
below the volume buttons there is an area to separate the case apart...once you get that corner apart you just gotta pull the rest of it apart...
Thanks, I did that but still nothing, too hard to pull the rest apart :'(
Well, I will keep trying, just do not want to break the whole thing.
I use a dime to pop it open, then slowly work my way around popping it loose as i go. At first i too was worried about breaking it, but don't be.
AciDDreamZ
