Skype LED notification and vibration don't work
Nikotod
5
Hello,
Doesn't matter if I'm on wi-fi or on mobile, skype led notifications do not work, nor the vibrate. Only the popping sound does. I've been re-installing the app, restarting the handset, turning options off and on, but nothing has helped.
It's kind of annoying and unreliable. Is anyone having similar issues?
--OS ver.: 4.0.4 unlocked i9300--
try the light flow app mate,lets you customise notifications for each app includin led colour + vibration. make sure it supports skype before you buy but it supports viber and go sms so probably does. the free version wont
global s3, UK. Ask me anything and ill reply even if its just an intelligent (or stupid) guess ;)
tota
