Slight problem with my screen.
Kalix Havok
Hello guys, as the title suggests, I have a small problem with a white rectangle appearing on my screen. It's not the wallpaper as I've changed them to try and fix it and it's not any app i can think of. Can anyone please help? It doesn't ruin my experience with the phone, but it does bother me being there. You'll see it on the bottom right. Thanks in advance everyone.
Looks like an app folder is stuck open. If you long press the tools folder can you move it out of that rectangle? Did you try a simple restart of the phone? Or a cache clear?
It looks like you may have had a widget there... try to drag it away, or maybe uninstall whatever widget it was.
bohanvo2
