Slow Droid Help?
BigKenW
49
Hi All,
My wife has a Droid that was running 2.1. It started running slowly once Good Email was placed on it (Her company requires it). This seemed odd. I just manually installed the official 2.2 update hoping some Froyo goodness would speed this sucker up.
Does anyone have any tips on optimizing the Droid to run faster? Anyone have similar problems with Good email? Any tips/links that might help?
Thank you!
-Ken
try the advanced task killer app
it closes the apps that are running in the background like the calender
it works great on my droid
The best thing you can do is contact the developer through the market and explain your situation. if they are quick to respond they may be able to tell you some tweaks you can make. Or perhaps they'll just improve the app. They may want you to send a logcat in to help out.
