• Welcome to the all-new Android Central Forums! - We're still moving some things around, so you may see a few quirks here and there, but we're working on getting things fully completed as soon as possible. For now, take a look around, and if you run into any major issues please let us know in this thread!
slowwww dataaa and heats up. help.
izohn
OK guys I'm new here so don't drill me on rules and posts and skip introduction.
Ok I have a galaxy s3 running 4.1.2
It was virgin mobile. But I recently flashed it to metro PCs. I use the phone heavily and noticed the data slows up really bad. I mean bad. And it starts to get hot while I'm on YouTube or watching movies or etc. Movies and videos stay buffering or loading.
i believe i have unlimited data I tried all the simple things like rebooting and turning data on & off I checked my apps. uninstalled unnecessary apps. I even turn on developer options and keep processes to 4 maximum. I have installed the speed test app and get 1.40 mb download max speed on a good day. Literally. WORST WAS 0.03 mb max. Is it the metro towers? Is it the flash? I just need a general answer pushing me in the direction of the problem.
As I post this my phone is a little hot and this link is a visual screenshot
http://i40.tinypic.com/2z9ifd3.jpg
Golfdriver97
Trusted Member Team Leader
Moderator
Dec 4, 2012
35,253
Your data speeds can be pinned to your carrier. The heat may be from the cell working harder to keep your signal if it is weak. If you can, post a screenshot of your signal. Go to settings>about device>status.
From a Sprint Moto X using the AC forums app.
Ask The Community
knkk
