Hello I have the same problem mentioned above. Smart cleaning just stops working when you select the Temp file, is there a fix for this instead of the "work around"? does my phone have a "bug"? should I go to my provider?
Just because the name has "smart" in it doesn't mean it isComputers have zero judgement. They are about as smart as a lawnmower.
