- Jul 29, 2012
- 8
- 0
- 0
What is the smoothest ROM for Optimus V that everything works?!?!
I need suggestions right now im on quattrimus ICS i like it but the video doesnt work :/
Thank You
Thank You
I'd definitely recommend Mirage. Its smooth as it is, then you over clock and it takes action
Thank you for your support! Do y'all think y'all could put the links to those ROMS?!?
