- Jun 2, 2010
- 15
- 0
- 0
So here's an App that I personally would love to see created. If I had any sort of Dev skills I would create it myself. My wife gives me grief if I don't respond to her TXTs/Answer the phone right away. The problem, is that I refuse to do either while I'm driving.
My guess is that I'm not alone in not wanting to be one of the many distracted drivers out there, and I bet there are others that would like an app that does this:
Idea for App
Use GPS to determine your speed.
If you are traveling at a speed greater than 10MPH (User defined) then send calls directly to Voice mail and setup an SMS auto response (user defined.)
Something like, "<auto response>I'm currently driving. I'll reply to your message when I reach my destination."
Once a phone reaches a speed greater than 10mph (user defined) a button is placed on the lock screen that you can hit once you have actually reached your destination/you want to disable the auto response. Also, you could auto disable after X minutes (user defined) below 10mph (user defined).
If done well, I'd totally buy an app that does this.
Idea for App
