SMS sound replacement?
Gravislord
Active member
May 13, 2010
27
I have not been able to find where to.change the SMS sound as it isn't using the Notification Sound. Anyone find it?
Sent from my HTCONE using Android Central Forums
My gosh, ditto! It is obnoxious and loud. I hope that the ringtone/ notification volume isn't the only option. I just want the text sound quiet and my ringtone normal.
It is also in settings>sounds and near bottom of screen. You can set text tone and notification tone. I'd you want custom tones you can get 3rd party apps to manage them.
Sent from my HTC One using Android Central Forums
francomattia
