Soft bricked and can't flash anything. plz help!
Veregund
Active member
Jun 4, 2011
33
Hey guys -
I think what I did wrong was try to flash StockED1 via ODIN while lagfix was enabled, and now I'm soft bricked and everything I try to flash via odin fails. Plz help, as I need a phone today! Thanks
Update: I got voodoo nicely flashed on now. But now I have a further problem: I can't open my text messages. Every time I try, it gets a force close. Sorry for all the problems; i have the worst luck with this stuff. Thanks
Hey guys -
Have you tried booting into recovery, wiping data/cache and reflashing whatever you're currently running?
I've installed the stock image via Odin even while lagfix was enabled multiple times and have never encountered problems. I think the lagfix needs to be disabled if you're installing via CWM.
I sometimes get problems when using Odin for strange reasons. What always works for me: putting in the battery after the yellow triangle image comes up on my phone (from pressing volume down key).
The first thing to try would be to clear cache and clear defaults.
Settings/applications/manage applications/"All" tab, click on Messenging/Clear cache then do Clear default.
Sent from my SCH-I510 using Tapatalk
I did a factory reset, and everything seems to be working great. However, my GPS is now not working. When I try to, say, use navigation, it just sticks on "Searching for GPS." GPS is enabled on my phone. Any ideas?
Omar Boresli
